Repair information, service guides, and troubleshooting help for refrigerators manufactured by Frigidaire.
82вопросов Показать все
keeping things cold just barely cool
Mr. Mayer, I have a Frigidaire 3.1-cu ft Freestanding Mini Fridge Freezer Compartment as found at Lowes. I bought it used but don't think its that old. Date Code is 16W10 if that helps. I have it at work and it has just stopped working right. At first we heard a fan type noise that didn't sound right and sounded like it was coming from the freezer area. Then it just was not keeping things cold just barely cool. I turned it off last thursday and have not turned it back on yet. The drip pan, that wont come out, has a lot of smelly water in it. Smells like someone crapped their pants which is what I thought at first LOL. How do I trouble shoot the cooling issue and what do you suggest to do about the standing water that smells?
Это хороший вопрос?
Оценка 0
1 Комментарий:
See if you can find the correct model number
из
Добавить комментарий
1 ответ
Hello, in order to cool anything you must dissipate heat, and I think your problem is just about that, if this type of fridge is using fans to cool-down the radiator then you should take a look at it firs and do not let your fridge on if it’s not working.
Был ли этот ответ полезен?
Оценка 0
Добавьте свой ответ
jraycd будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 3
За последние 30 дней: 5
За всё время: 63
