iPhone 7 plus был выпущен 22 сентября 2017 года и увидел свет в качестве двух модификаций: A1863, A1905. Поставлялся с двумя различными модулями мобильной связи: GSM или CDMA, а также с 64 Гб или 256 Гб встроенного хранилища. Цвет корпуса можно было приобрести золотой, серебристый или Space Gray.
How do you fix a bent iPhone charger?
So i was sleeping and suddenly i accidentally dropped my phone and it was charging so both fell and i realized my charger is bent. Please help if not my parents are gonna kill me.
Update (07/16/2019)
here it is. it looks like it’s never going to be fixed :(((
Update (07/16/2019)
update: i can’t charge my phone
Update (07/16/2019)
Это хороший вопрос?
Счет 4
Добавить комментарий
6 Ответов
Наиболее полезный ответ
Like Owen said,it’s probably not worth it. You can get the apple oem cable for $20. There are $10 cables too,but some of them are not safe in the case of a voltage surge.
Был ли этот ответ полезен?
Счет 1
I mean you can buy a new cable from Apple for around $20. Or go to a gas station and just buy one for a few dollars. You could try bending the cable you have now back to its place but the fact the it doesn’t work means you should probably just throw it away.
Счет 0
1 Комментарий:
i’m from Singapore and it’s expensive as !&&*
из
Honestly I can)t let go of things that easily so throwing it away will be hard and I am a bit stubborn, so Ima keep trying >:)
Счет 0
1 Комментарий:
i know exactly what you mean, but sometimes broken is broken.
из
Just buy a new one
Счет 0
mine was severely bent, idk bout you but when my phone is charging for a long time, the charger can be bent more easily because of the heat, mine used to be 110° while it was charging and sitll very hot i bent it very slowly and carful kt and now it’s at 30° but now i have it tilt it at an angle to make sure it gets charged
Счет 0
Where it is bent would be extremely difficult to repair without replacing the end which defeats the point of repair. Also it could be a potential fire hazard if not done correctly.
Счет 0
Добавьте свой ответ
Anoj буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 3
За последние 7 дней: 29
За последние 30 дней: 157
За всё время: 25,512
