The Buick Lucerne is a full-size upscale sedan sold by Buick from 2006 to 2011.
Car shuts off when warmed up
car starts and runs fine until engine heats up to operating tempature, then it stalls, it will restart but keeps stalling until engine cools down. What can cause this?
Это хороший вопрос?
Счет 0
1 Комментарий
I'm having this problem with 1992 Buick Century 3300. Shuts off when it reaches operating temp. I replaced the fuel injectors, thermostat, coolant temp sensor, and intake manifold gasket. Car still stalls.
из
Добавить комментарий
2 Ответов
Наиболее полезный ответ
Hey akajuwan.
A failure with the Crankshaft Position Sensor, the Ignition Control Module, and/or the Throttle Position Sensor could cause intermittent stalling. That said, it’s important to check the wires and connectors (pins) associated with these aspects, as corrosion or physical damage, etc., to the wires or connectors could actually be the problem, and not the actual sensor or module.
Might be able to provide more helpful info if you would provide the details on your model.
Был ли этот ответ полезен?
Счет 2
Possible it could be a cracked distributor cap, when the car warms up cap expands causing fire to jump and run badly or not at all.
Счет 1
Добавьте свой ответ
akajuwan буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 1
За последние 30 дней: 10
За всё время: 1,175
