2.2 GHz (Turbo Boost up to 3.4 GHz) or 2.5 GHz (Turbo Boost up to 3.7 GHz) quad-core Intel Core i7 processor with 6MB shared L3 cache.
467вопросов Показать все
MacBook Pro mid-2014 15” iSight replacement
Hi, My webcam on my Macbook Pro mid-2014 15” seems to be broken… I tried all methods online to see if its possible to get it back working.. but none of the methods worked. I wondering if it possible to replace the webcam?
I can’t seem to find replacement parts or guide for this model.
Thank you :)
Это хороший вопрос?
Оценка 1
Добавить комментарий
2 Ответов
Выбранное решение
It’s almost an impossible repair, webcam is behind the retina screen and chances to remove it without breaking it to access the webcam are very close to zero, hence the lack of guides or spares, you would have to replace the screen assembly.
Был ли этот ответ полезен?
Оценка 3
2 Комментариев:
ah... so there is no way of fixing this problem.. any alternative methods?
из
@Jason Kim There's always the chance the camera is fine and malfunctioning depends on the logic board circuitry, but that needs someone into component level repairs. If it's the camera itself I can't think of any other possible fix than replacing it, but we get back to step one.
из
Наиболее полезный ответ
See step #5 of this guide. Reseat your camera to logic board connector and examine the cable for anomalies:
MacBook Pro 15" Retina Display Mid 2014 Logic Board Replacement
Оценка 4
Добавьте свой ответ
Jason Kim будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 6
За последние 30 дней: 22
За всё время: 2,580
