Дата выхода 25 сентября 2015 г. Модель A1688 / A1633. Ремонт данного устройства схож с предыдущими моделями, требующий отвертки и инструменты для вскрытия. Доступен в версиях GSM или CDMA; с 16, 64 или 128 ГБ памяти; в цветах: Серебристый, Золотой, «Серый космос» и «Розовое золото».
2690вопросов Показать все
Not charging even with new battery
Hi
A few weeks ago I dropped my iphone 6s in the water, it all worked fine could charge and so. Until a few hours later I couldn’t charge anymore so I thought the battery was dead. I checked this theory by using a volt meter and the pins connected to the battery gave out a good voltage when connected to the power outlet. So I bought a new battery and just replaced the old one. My iphone got back to life however it still won’t charge ?!? even tough the pins gave out a good voltage. Any thing I can try or should I just give up ?
thx
Это хороший вопрос?
Оценка 0
Добавить комментарий
2 Ответов
Выбранное решение
I think you have done all you can for a water damaged phone unless you want to try a new dock connector. Your phones charging circuit on the logic board will be the problem for now, and then other problems will arise. I would not spend any more time or money on this device.
Был ли этот ответ полезен?
Оценка 2
1 Комментарий:
yea I guessed so, its just wierd it gives the charging symbol and I get a voltage but it doesn't charge :-(
из
Have you tried cleaning the the charge hole? I found there gets a lot of dust and crap in a tiny space and the wire won’t connect! Use a needle and try digging around, you’d be surprised
Оценка 1
1 Комментарий:
I have, maybe will try to do it again, however it shows the symbol of charging on the phone and the pins give voltage so I don't think thats the problem ? because ig gives power
из
Добавьте свой ответ
Goldppl будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 1
За последние 30 дней: 1
За всё время: 51
