Apple AirPods are wireless headphones released December 2016.
94вопросов Показать все
incredibly low volume and a ton of sound leakage
ok so ill get it out of the way with the general unpairing and repairing or the reset your AirPods or to suck on them. tried em all. any guide on the internet on how to fix this has not helped me what so ever. so in summary my AirPods when I use them are to the point its a struggle to listen properly to music when the volume is at 100%. also when im using them at 100% volume people around me can hair what im playing way louder then I can. not only that. this is my second pair of AirPods. the same happened to the first pair then I got them replaced. unfortunately its now too late to get these replaced too. does anyone have any ideas about where I should go from here? or do I give up and just take it too apple and see what they can do.
thanks in advance for any responses
Это хороший вопрос?
Оценка 0
Добавить комментарий
1 ответ
Наиболее полезный ответ
With very low volume, I fixed mine by using isopropyl alcohol and a qtip/ear bud. Gave it a good deep clean and restored sound perfectly for me.
Был ли этот ответ полезен?
Оценка 1
2 Комментариев:
hi there. thanks for the response but unfortunetly thats something I've tried too. sadly didn't work either but ill admit the volume was slightly better for a day then went down hill again after. volume still wasn't as good as it could have been. thank you anyways
из
@Finnlay Worchurst not a problem, just thought I would share something that worked for me.
из
Добавьте свой ответ
Finnlay Worchurst будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 7
За последние 30 дней: 56
За всё время: 3,683
