Apple's third-generation smartwatch, with optional cellular connectivity, released September 22, 2017.
197вопросов Показать все
Does anyone know what this is?
I don’t know what this is. It doesn’t look to be a part of the original WatchOS. I can’t leave the menu and both options lead back to the same menu. Already tried a force restart by holding both buttons down until it boots back up. I bought the watch like this so I can replace another watch’s screen, but I just wanted to see if I could do anything about this.
Это хороший вопрос?
Оценка 0
Добавить комментарий
2 Ответов
Наиболее полезный ответ
You’ll need to visit an Apple Store for them to reset the watch via the diagnostic port. Just under the strap cavity is an access port so the watch can be put into DFU mode.
Был ли этот ответ полезен?
Оценка 1
That is part of the original watch OS. It appears when you press and hold the side button and then do a firm press on Power Off before letting go. However, it’s strange that a hard reset hasn’t solved the issue. What happens when you factory reset the device? Are you able to? Is it an endless loop no matter which option on which screen you choose??
Оценка 0
1 Комментарий:
Resetting the device leads to the same menu again. It's a constant loop no matter what I choose or do.
из
Добавьте свой ответ
Derek Bryant будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 1
За всё время: 81
