S8 новейший флагманский смартфон компании Samsung, представленный на Unpacked 2017 в апреле.
304вопросов Показать все
Do I need to do anything in the software after replacing the battery?
I used AccuBattery to estimate my battery capacity before replacing it and I was getting around 2500 mAh. Now after replacing the battery my battery life is significantly worse and the app now estimates the capacity is only 2100 mAh. Do I need to do anything in the OS to calibrate the battery after replacement?
Это хороший вопрос?
Оценка 1
Добавить комментарий
1 ответ
Hi @rogertiu ,
after this change, you can calibrate your battery, but it’s not necessary. I don’t know, where did you buy your new battery, but the capacity of a brand new battery from manufacturing is having a higher capacity then it is written in the description of the phone. On the contrary, every next battery will have a smaller capacity, especially batteries from “non-original services” will have much lower capacity, then original.
Anyway, there are tips for calibrate your battery with rooted and without rooted device.
Был ли этот ответ полезен?
Оценка 0
2 Комментариев:
Thanks for the information! I purchased the kit from ifixit. I will contact them to see if they can help.
из
@rogertiu You are welcome! Good luck, let us know, how does it go.
из
Добавьте свой ответ
Roger Tiu будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 2
За всё время: 87
