Why is my riding mower engine revving uncontrollably?
I have a Husqvarna riding mower with a Briggs & Stratton motor model number 44 R877. The type number is 0 0 0 1 g 1 and the code is 14032 0 YG. I have checked the springs on my linkage and there is no visible damage they are not stretched in any way. And my throttle seems to be moving okay. And my Governor seems to be set correctly? Any ideas on what else it could be?
Это хороший вопрос?
2 Комментариев
@sammymom "engine revving uncontrollably" high or surging from low to high? Does it do it immediately on start up or after it warms up etc.
из oldturkey03
Thanks for the advice. Took the motor apart and found the Governor was not set right.( Husband didn't know you were supposed to set it when he put it back together the first time) will set it this time. Will also follow up on your advice after we get it put back together. Will let you know which one is the culprit. Thanks
из Cynthia
