LG LM270WQ1 (SD) (BD) backlit replacement
I have a workstation HP Z1 all-in-one with the backlight working partially, in the overall is good but on the left is dimmer. I found online the option to replace the screen but the exact model is impossible to find without moving with hp spare part which is extremely expensive, considering I have taken a refurnished model. The screen is LG lm270wq1 (SD) (BD) and I found a lot of different end code (A1) (B1) (E3), so I want be sure to find the best and cheap way to restore the backlight, are those model compatible? Is there a website where I can buy just the backlight?
Attached 2 pics with the faulty and the serial
Thank you all in advance for the support
Это хороший вопрос?
4 Комментариев
I have an HP Z1 with the LG 27" display. It exhibits the exact same "backlight shadow" as shown above.
I've replaced LED backlights in a 50" TV, so I have an idea of what's involved.
My question is, on this panel, are there rows of left and right LED strips behind the panel, or are they just along the top and bottom (edge lit)? Thank you kindly in advance.
из Duncan McAllister
@Duncan McAllister should be an edge lit monitor but it will depend on what panel they popped in there. Once you remove the back cover check the label and try a search for the datasheet
из oldturkey03
Thank you kindly for your timely response. It's one of the LG LM270WQ variants.
I got the thing apart and there are two LED strips along the bottom edge of the panel. The left strip is shorted -- all the individual LEDs test OK with a meter.
But on startup, the strip just flashes for a second, and then the PSU shuts it off. I removed and resoldered the connector with a hot air station, but no dice. I've ordered a new pair of strips.
I'm going to try to photograph the various steps when I reassemble the panel. I think it would be useful to have a step-by-step teardown of the actual panel itself, with all the different layers. That's one thing I couldn't find anywhere online.
Hi To All that experienced same problem. I have two Z1 and on both, I had the same problem. First time I have to buy a new panel from eBay and the same thing happen after 2 years. The problem is in Poor cooling of the system. LED stripes are at the bottom but they create a loot of temperature and in fime connector that is on LED stripes lose connection and need to be soldered with new material. My friend that has a microscope, soldered them and we now have everything working. So dare is no need to change all panel, just carefully disassembly panel. Anyway you can do anything wrong since your panel is already half useful. For dose that is not careful and skillful for this operation, I suggest not to do it. Be careful to mark all layers and make photos witch goes where and when. Led stripes can be ordered from Aliexpres if you don't want to solder your old one. Hope this will help you. BR
из Sasa Raca
