The Acer Aspire Switch 10 SW5-011-18R3 is a 2-in-1 Tablet with docking keyboard running Windows OS. It was originally released May 2014.
Device won't turn on
My Acer Aspire 10 won’t power on, though I have an LED power light. I opened up the inside and reattached almost every cable, and it still won’t power on. I have went through almost every tutorial and still cant’t find an answer.
Это хороший вопрос?
Оценка 2
1 Комментарий:
Try reconnect battery connector (it help me, after that I can power on )
из
Добавить комментарий
Ответов (2)
Solution:
Please follow steps in iFixit guide - I hope, It will be solved easily.
Был ли этот ответ полезен?
Оценка 0
2 Комментариев:
@lucasjak Where is the ram slot?
из
I'm sorry, the first answer was my mistake, I forgot, that this is not a laptop, but 2 in 1 device. Please, check out a new answer, I hope, it will be helpful.
из
If you haven’t done anything before you notice the problem then it must be related to the ram, you need to remove it, blast air in the slot, clean the ram with paper and put it back.
Оценка 0
1 Комментарий:
I cannot find the ram slot on this computer. I am pretty sure it has internal ram, and it cannot be removed / replaced.
из
Добавьте свой ответ
Max Uchenik будет очень признателен(а).
Статистика просмотров:
За последние 24 час(ов): 0
За последние 7 дней: 1
За последние 30 дней: 13
За всё время: 608
