Выпущен 16 сентября 2016 года. Модель 1660, 1778. Стандарты связи GSM или CDMA. Память 32, 128 или 256 ГБ. Цвета: розовое золото, золотой, серебристый, черный и глянцевый черный.
2264вопросов Показать все
iPhone screen is black but backlight is on
my iphone 7 screen is black but the backlight is on after a screen replacement. when i first connected the flex cables the apple logo DID show and turn on but the screen itself wouldn't swipe etc so i disconnected and reconnected with the battery disconnected and went to turn it back on but i got stuck on the apple logo and the creen went black but the backlight was on. so i bought another screen and now both ofthem are black but he bcklight is on hheellppp!
Это хороший вопрос?
Оценка 0
Добавить комментарий
1 ответ
Наиболее полезный ответ
By seeing that history of that something mishmash while change LCD.That problem accidently happen while putting LCD, while on on-condition or some parts that connect to LCD connector on PCB gone damage or remove while removing LCD.
Better for the solution by my view.
1 - See the LCD connector pin ok.
2- First conform that without graphic phone detect by iTunes or Detect as DFU mode on iTunes.
3 - See the parts near LCD connector might be broken.
Был ли этот ответ полезен?
Оценка 1
2 Комментариев:
i checked the connector pins all look good ill check itunes as soon as i get to a computer
из
hi! just an update i tried to connect to a computer and its not being recognised i also got another battery but still nothing i tried another screen nothing again. i did however notice the part inside next to the power button got EXTREMELY hot (maybe the processor?) maybe i can change it?
из
Добавьте свой ответ
michelle roark будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 11
За всё время: 270
