S8 новейший флагманский смартфон компании Samsung, представленный на Unpacked 2017 в апреле.
304вопросов Показать все
Should I replace the glass, the digitalizer, or the whole phone?
I cracked the glass on my S8 edge forever ago…it was pretty bad but it was tolerable I could still see everything…it got dropped or fell a few more time, the last time this happend it got a much deeper crack and the screen doesnt work. 75% of the screen is white and I can't see anything for the most part however the screen still responds to my touch. The phone still totally works when I touch the screen, it can still run whatever program I open but I can't see anything. I went to my local repair shop and it was going to be much more expensive than I thought. I'm not sure if I should replace the glass or the whole setup….any advice?
Это хороший вопрос?
Оценка 0
Добавить комментарий
1 ответ
Выбранное решение
You’ll have to replace the whole display. Replacing the glass would do nothing for your image. The amoled panel is broken. Also, most repair shops quote for a whole display regardless if the amoled panel is working or not because it is almost impossible to replace the glass on Samsung curved displays.
Был ли этот ответ полезен?
Оценка 1
Добавьте свой ответ
Brianna N будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 4
За последние 30 дней: 4
За всё время: 50
