The March 2015 update of Apple's 13" MacBook Pro Retina Display, model A1502, features fifth-generation Intel Core i5 and i7 processors and introduces the Force Touch trackpad.
1185вопросов Показать все
Trackpad not working but keyboard is
I have a 13” 2015 MacBook pro and the trackpad stopped working but the keyboard is working fine. Could it be the ribbon cable or the trackpad itselt?
Tried resetting all kinds of things but did not help.
Это хороший вопрос?
Оценка 0
Добавить комментарий
2 Ответов
Наиболее полезный ответ
I would start with the cable as it can be damaged by grit and pressure from the bottom cover and battery MacBook Pro 13" Retina (Early 2015) Trackpad Cable
It’s also possible the trackpad damaged. I have had to replace a few as people tend to spray cleaner directly on the case and the cleaner can drip into the gap between the case and the trackpad and works its way into the sensor sandwich damaging it MacBook Pro 13" Retina (Early 2015) Trackpad.
MacBook Pro 13" Retina (Early 2015) Trackpad Изображение
Продукт
$54.99
MacBook Pro 13" Retina (Early 2015) Trackpad Cable Изображение
Продукт
$9.99
Был ли этот ответ полезен?
Оценка 1
2 Комментариев:
Sensor sandwich! :)
из
@kadan - Take a look at the Magic Trackpad Teardown
And here's a better view of the sensor grid within it Sensor Array from the Magic Mouse. Unlike the mouse its flat and the connections are on the edge to the logic board.
из
Before replacing the trackpad, make sure to check if it’s the SMC. Use this link.
Оценка 0
Добавьте свой ответ
nugety будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 1
За последние 30 дней: 1
За всё время: 159
