Power cord is not working
I have an epilator (HP6543) whose power cord is not working. Is it possible to get it replaced?
Это хороший вопрос?
Счет 0
1 Комментарий:
FWIW, decide to do a search and ran across one post from a lady who stated she has resolved to buying 4 new units due to power cord failure (she obviously likes the job the unit produces), but alas, saw no idication of a replacement power supply available for that unit. (Others google-fu may prove different). You maybe able to source a generic li-ion battery charger if you know the voltage etc specifications. Personally if it was my unit and it was the cord that had broken, I would just open the power supply casing and wire/solder in a new cable. Maybe you or someone you know could do that? Anyways, hope you get your problem fixed. :-)
из
Добавить комментарий
