The smaller of Apple's MacBook Air laptops featuring dual microphones and 802.11ac Wi-Fi connectivity.
149вопросов Показать все
Why is my new MacBook Air battery not charging
The issue is with a MacBook Air, mid 2013.
The old battery was working, but cut out when it hit 40% or so. Bought a new battery, followed the directions carefully, but the battery isn’t charging. It says 0% and the battery icon won’t appear in the menu bar. Reset the SMC, opened it a second time and reset the connection and still nothing. As the one comment on this section noted, the connector needs to be folded a bit shorter so that the plugs meet, which I also discovered and did.
So why isn’t it charging?
Это хороший вопрос?
Оценка 1
Добавить комментарий
1 ответ
Наиболее полезный ответ
What are your Mag-Safe light telling you?
Please download and run Coconut Battery to give us a much better idea of what your battery is doing. Please post those results:
https://www.coconut-flavour.com/coconutb...
Был ли этот ответ полезен?
Оценка 2
Добавьте свой ответ
Daniel Siegel будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 2
За последние 7 дней: 2
За последние 30 дней: 3
За всё время: 136
