3ds XL Problem with Top Screen
The top screen looks like it has a white filter or blur.
I just replaced the top screen lcd but i still got the exact same problem. I checked all 3 of the ribbon cables for any tear, but there isn't any. I tried reseating all 3 top ribbon cables 8 times but still doesnt fix the problem.
Sometimes it returns back to normal after a few days of leaving it alone but then it reverts back to that state
I have this problem since 2015 so i just bought another one back then but i recently found this on our storage and wanna try to fix it.
Это хороший вопрос?
Just a thought. Reseating a cable is one thing but continuity in each wire in each cable is another. In other words, there may be one or more wires internally making and breaking inside a cable. This would cause an intermittent condition which may be the source of your problem clearing up and then appearing again. If applicable may be swap cables with your good unit or grab a multimeter to check continuity (which could be a real pain in the buttocks) or see if you can buy some new/used cables for testing. You may also have an intermittent and/or failing component, cold/cracked solder joints etc. If nothing readily apparent when doing a visual check, pay really close further attention to dodgy looking solder joints; try wiggling components for signs of displaying excessive movement.
из prop man
Well those are not in my area of knowledge. I guess ill give doing it myself and bring it for professional repairs
Thank you
из 4reaka
