CDMA версия четвертого поколения iPhone. Ремонт прост, но дисплей должен быть заменен в сборе с сенсорным стеклом. 16 или 32 ГБ памяти / Модель A1349 / Cовместимость с CDMA.
295вопросов Показать все
Power button not clicking after disassembling
Ok, so I was attempting to do a screen replacement on a iPhone 4 CDMA, and i wanted to disassemble the power button as it was not clicking before. However, once i took the physical power button apart and checked the power cable flex, everything seemed tip-top. Only problem i have is when i tried putting it all back together, after screwing everything back in and aligning the power button, as it was crooked, the satisfying click wasn’t there and I do not know why. I re-disassembled again and check the ifixit guide here to see if i didn’t miss a step or whatnot. Click was still not there. Is there like a part that i’m missing to get that click or do i have replace something to fix this?
Это хороший вопрос?
Оценка 0
Добавить комментарий
1 ответ
Did you place the small back plate in-between the cable and the plate ??
Был ли этот ответ полезен?
Оценка 0
1 Комментарий:
there's a backplate sandwiched to the power button and the device?? I'm not sure, i have to check for myself
из
Добавьте свой ответ
Juan Jimenez будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 1
За последние 30 дней: 2
За всё время: 27
