The fourth generation Nissan Altima (chassis model L32A) was announced at the 2006 New York Auto Show on April 12, 2006. It was the first vehicle to use the smaller Nissan D platform, with a new front and upgraded rear suspension.
Вопросов 20 Показать все
Altima coupe headlights flicker and cut out
2009 altima coupe headlights flicker and cut out. Been having issues with driver side, flickers once in a while then will cut out. Can turn headlights off and back on and everything comes back on like normal. Passenger side is now flickering as well.
Это хороший вопрос?
Оценка 0
Добавить комментарий
Ответов (1)
My first thought would be a bad or partially broken bulb. Hit any hard bumps lately?
Any other lights flicker at all when you switch your headlights on, like your brake lights or dash lights? Does it improve it all or change behavior when you play with the headlight switch?
Because it is affecting both sides of your headlights, assuming the bulbs are good, I would then look at the fuse/relay for the headlamps followed by the headlight switch being the possible causes. A corroded or failing fuse/relay could display similar symptoms.
Был ли этот ответ полезен?
Оценка 0
Добавьте свой ответ
James McConnell будет очень признателен(а).
Статистика просмотров:
За последние 24 час(ов): 0
За последние 7 дней: 0
За последние 30 дней: 5
За всё время: 1,097
