My rear taillights is not working.
I Have a 1989 Toyota Corolla.
My Taillights don't work Please Help
Это хороший вопрос?
Это хороший вопрос?
@precious6616 you are looking for the tail light assembly. Relatively expensive and I would check with a recycler (wrecking yard) in your area.
Был ли этот ответ полезен?
Thank You ☺ oldturkey03
oldturkey03
I'm not talking about the lamp on the outside. I need the name of the electrical box on the inside of the trunk. Where the bulb's go in. Not the out side of the trunk.
@precious6616 that is correct. the outside is the lens whereas the assembly is actually the lens and the back of the light that has the bulb mounts etc. in it.
I would need more information to make a good diagnosis, but I would start by checking the fuse box and the bulbs. It might also be worth checking the wiring if none of that works to make sure there is no short circuit with the frame or something.
All the fuse's and bulbs are good. The wiring is good, but one off the pieces where I place the bulb in is burned inside the metal part. I just want to know what the hold control panel is called & where can I purchased it.
За последние 24часов: 1
За последние 7 дней: 8
За последние 30 дней: 23
За всё время: 341
