Released in North America in November 2006, the Wii was Nintendo's first home console to directly support Internet connectivity, supporting both online games and digital distribution of games and media applications through the Wii Shop Channel.
286вопросов Показать все
Screw of CMOS battery door is threaded.
Help I have no idea what to do I accidentally threaded the screw of the CMOS battery door and I cannot remove it. I also need a replacement as I'm pretty sure the slot would be damaged when I remove it.
Это хороший вопрос?
Оценка 0
Добавить комментарий
1 ответ
Наиболее полезный ответ
You cannot unscrew it to get it out, if you screw it in, does it stop or continue to spin? If it stops, you will need to drill the head off, remove the cover and see what you can do to fix the female receptacle as you are thinking.
Был ли этот ответ полезен?
Оценка 1
1 Комментарий:
It stops but I am scared at the thought of drilling it since I might damage the system.
из
Добавьте свой ответ
harsh la Rose будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 3
За последние 7 дней: 4
За последние 30 дней: 6
За всё время: 301
