iPhone X Boot loop! Low battery then Apple Logo
I’m having issues with my iPhone X. When I try switch it on ordinarily, not plugged in or anything it shows the screen that prompts you to plug the phone in to charge. When plugged in the phone goes to the screen which shows the iphone is plugged in but low charge. It then displays the apple logo for about 5 seconds, then goes black, then goes to the low charge screen again. It keeps repeating this no matter how long its on charge for.
I’ve tried putting the phone into DFU mode by pressing the volume up bottom, then the volume down button then the power button it then goes to the restore screen where it asks to plug it into itunes. Itunes doesn’t detect the phone at all, was expecting it to prompt me to restore and update like it normal does.
Have been thinking about replacing the battery to see if that’s the issue as it doesn’t seem to be taking charge at all
Any help would be massively appreciated
Update (09/22/2019)
Hi everyone, the situation has now advanced in a good way! I disconnected the battery, disconnected the screen and then connected the battery back up. Pressed up, then down then held the sleep key and to be shock it detected the phone!
From here I restored the phone and updated to IOS 13. I’ve now got to the welcome stage of the phone on iTunes however when I connect the screen back up it goes back into a boot loop!
The screen appears to be the issue here I recon. Should I just get a new screen? I’ve checked the connections on the motherboard and they seem okay no visible damage or dust in there. Not too sure what to do
Это хороший вопрос?
1 Комментарий
Yes, replace the battery first.
из Chris Stables
