Printer Wont turn on
Plugged and Unplugged after recieving error code B203, and after leaving it unplugged overnight, the Printer WILL NOT TURN ON :( any suggestions as to what to do.
Это хороший вопрос?
Это хороший вопрос?
if no power try replacing the power cable,
if it is error B203 try the below link steps,
Sometimes, the Error Code B203 indicates that there is an empty ink cartridge. Now, if your Canon printer is running on two different kinds of ink cartridges. Then, it might possible that one of them is empty and that is creating this error on your system.
or tey doing a hard reset : LINK
Был ли этот ответ полезен?
За последние 24 часов: 2
За последние 7 дней: 5
За последние 30 дней: 17
За всё время: 4,975
This happened to my MG6650. I didn’t use it for a month and when I turned it on it initially showed this error and I wouldn’t let me do anything. Well I tricked it and it started to print but turned off after a second. After that it would not turn on anymore.
из Toni
did you change the power code and check, did you try with a different power outlet
из SHIHAM IFTHIKAR
@shiham Well I tried a different power outlet but didn‘t change the cord. The cable should be fine.
из Toni
