Announced September 9th, 2014, this device is Apple's first foray into smart wearables. iFixit's repair manuals are applicable to Apple Watch (steel) and Apple Watch Sport (aluminum).
210вопросов Показать все
Screen replacement, cable included?
Sooo my entire screen popped off, ripping the cable in half… Does the screen parts here come with that cable? If not, what do I need to get for it? Everything was working 100% before the incident, so I doubt the old screen is bad.. But I also doubt the cable alone is avail.
Это хороший вопрос?
Оценка 0
Добавить комментарий
1 ответ
Наиболее полезный ответ
Ouch!
If you have the original AppleWatch then the display cables are part of the display as you can see here
If you have the Series 1 and onward the cables are part of the SIP module
At that point you’ll need to think how important the watch is to you. A new SIP module is more than getting a new Series 3 watch!
Был ли этот ответ полезен?
Оценка 2
2 Комментариев:
It's def the original one, no multi cables out.. theres one that goes into this big metal clip thing, and the out part going into the watch ripped in half, but looking at that, and digging more, it looks like its the display cable that normally would be attached to the box marked taptic engine... Made a nearly clean rip right across where it was glued to that box...
из
Ouch!
That's the cable to the SIP, sorry not replaceable! You'll need a new SIP so at this point not worth fixing.
из
Добавьте свой ответ
Jerrica Liles будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 1
За последние 30 дней: 1
За всё время: 44
