Debuting in 2002, the first generation Sorento was a traditional truck-based body-on-frame SUV.
11вопросов Показать все
2008 Kia Sorento won’t start or nothing in the inside wont come on
My 08 Kia Sorento won’t start the fans headlights and horn comes on but my dash won’t come on or nothing in the inside will come on?!?!?!
Это хороший вопрос?
Оценка 0
Добавить комментарий
2 Ответов
The lights and the horn are located on what is referred to as the battery buss, everything else is energized after the key is turned on. Can you also verify if the emergency flashers are working, do you have a clock that you can pull out and your radio that can be pulled out. Can you gain access to the computer also. All of these items have power from the battery at all times.
The first serious place I would test is the ignition switch, when you insert the key and turn it one click you should get power to the accessories such as the radio and clock BUT the radio and clock need power all the time to hold the internal memory. If other items do not have battery power at all times then that will narrow down your diagnosis path.
Был ли этот ответ полезен?
Оценка 0
I would check your relay in the fuse box under the hood
Оценка 0
Добавьте свой ответ
Donjazase Toney будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 1
За последние 30 дней: 7
За всё время: 231
