Explore comprehensive repair and disassembly guides for a wide range of food-cooling appliances. This is your go-to solution for troubleshooting and fixing refrigerators, fridge-freezers, and other cooling units. Whether you're dealing with common issues or looking for step-by-step instructions on specific models, our detailed guides cover everything you need to keep your appliances running efficiently. Perfect for both DIY enthusiasts and professional repair technicians.
1698вопросов Показать все
Drain hole in freezer
Where is the drain hole in the bottom freezer?
Это хороший вопрос?
Оценка 0
Добавить комментарий
1 ответ
Наиболее полезный ответ
Please give us you make and model number.
The drain hole is usually located at the lowest level of the interior of your refrigerator. Try removing the bottom drawer in your refrigerator. It should be in the bottom.
Был ли этот ответ полезен?
Оценка 1
Добавьте свой ответ
mbancroft305 будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 0
За всё время: 88
