Device and repair guides for the RCA 10 Viking Pro, an Android tablet with detachable keyboard that can be identified by model number RCT6303W87 DK.
How much is it to get my charging port fixed?
My micro USB charging port is possibly broken and I have to hold the charger in.
Это хороший вопрос?
Счет 0
Добавить комментарий
1 ответ
Выбранное решение
It has a DC jack and a Micro USB port. Both can charge the battery. So which one is broken ? If both is not charging your battery, your battery should be replaced. If one of the ports isn’t doing anything, you should replace the port which is broken.
Please check this out regarding the ports: https://www.manualslib.com/manual/105408...
Был ли этот ответ полезен?
Счет 2
Добавьте свой ответ
Justin Lucas буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 0
За последние 30 дней: 0
За всё время: 87
