My phone sim not working its come emergency call only
emergency call only my phone problem p20 lite
Это хороший вопрос?
Это хороший вопрос?
Go to dial pad and type # *# *4636 # * # *. Now your phone is in testing mode. Go to Phone Information and scroll down. Click on Turn off radio. Once it is on, selects the network according to your country network from the above option. If your SIM card is 4G, then select LTE. When selected, click on Turn on Radio again and wait for the network to connect. It is suitable for all smartphones.
Был ли этот ответ полезен?
does not work
За последние 24часов: 1
За последние 7 дней: 13
За последние 30 дней: 34
За всё время: 3,395
emergency call only my problem
из Traveller photography
Can you try this combination *#06# and tell us if two numbers are showing or not without sharing them (for security reasons).
из Vertinhol
Can u try with anther SIM card? is there enough money in your sim card?
из Edward C
My sim slot isn't reading my sim, cause water got inside.... I tried the rice solution... Is there a way to make it work without replacing the motherboard? (cheap way)
из Ronald Matshavha
