The Sony Handycam FDR-AX33 is a palm sized camcorder that combines 4K video with video stabilization. It was released in March 2015, and was the first camcorder to introduce the new Balanced Optical SteadyShot (BOSS).
How to fix a lens in this camera sony ax 33
е: ошибка 61: 30
Как исправить объектив в этой камере. Второй раз за 2 года он ломается. Петля была изменена в камере уже. А потом обратно.
Где находится этот цикл и как его заменить?
Google translation
e: error 61:30 How to fix the lens in this camera. The second time in 2 years it breaks. The loop has been changed in the chamber already. And then back. Where is this cycle located and how to replace it?
Это хороший вопрос?
Счет 1
Добавить комментарий
7 Ответов
Выбранное решение
Top Device error E: 61: 30 means issue of the lens driving part. this “The loop has been changed in the chamber already. And then back. Where is this cycle located and how to replace it? “ seems to get lost in translation. I attached the disassembly part of the manual to the answer so you can hopefully find what you are looking for. Sony FDR-AX33 Disassembly
Был ли этот ответ полезен?
Счет 2
Hi, I have the same problem in my FDR-AX33 Error E:61:30.
The description gives me problem with “Issue of the lens driving part”
Can you help me identify which part or parts are necessary to exchange?
Rgds
Miguel Silva
Счет 0
Hello,
I´m with the same problem on the same camera AX-33 error E61:30. The sceen is white with some noise.
I will try to get a quote from Sony or someone can help?
Regards.
MS
Счет 0
Same Issue at my Camera, no solution ahead?
Счет 0
ME DA LA SENSACIÓN QUE ES UN ERROR PROGRAMADO.
LE HE DADO SIEMPRE UN TRATO EXQUISITO Y DELICADO Y DE LA NOCHE A LA MAÑANA ME DIÓ EL ERROR E:61:30
NO ENCUENTRO QUIEN ME ORIENTE, SOLO LLEVARLO AL SERVICIO TECNICO.
MI EXPERIENCIA EN LOS SERVICIOS TECNICOS ES QUE LO REPARAN Y AL POCO VUELVE A FALLAR CON EL COSTO ALTO DE PERITAJE Y DESMONTADO. Y LA DUDA DE SI NO LO QUIERES ES COMO VENDRÁ …
DICEN QUE ES QUE CADA CIERTO TIEMPO, HAY QUE HACERLE REVISION DEL MECANISMO DE DESPLAZAMIENTO DE LA LENTE QUE POR SUCIEDAD SE ATORA (CLARO LLEVÁNDOLA A UN SERVICIO TÉCNICO Y A PAGAR).
ESTOY PENSANDO UNA NUEVA PERO CAMBIARÉ DE MARCA CON MÁS CONFIANZA.
EN ESTA TENÍA FE PERO YA NO ME FIO.
Счет 0
My Sony FDR AX53 touch response on its LCD isn't working. There's no physical damage or scratches or anything, it all of a sudden stopped working. will this guide work for an AX53 Model ? As I'm being quoted £200 for a repair. i have fixed iPhones professionally for 6 months at an old job including full rehousing of later models. I'm thinking i just give it a go of repairing it myself as the new part will only be £90.
please let me know what i should do
Счет 0
1 Комментарий:
@jasperwolf here is the SM for the AX53 Sony FDR AX53 SM It does have the disassembly etc. It should have all you need to fix your Sony
из
anyone know where i can buy a sony FP-2299 flex.
Счет 0
Добавьте свой ответ
Top Device буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 4
За последние 30 дней: 23
За всё время: 2,777
