Vertical green lines on screen after HDD replacement?
Hello there,
i recently replaced my iMac mid 2007 HDD with a SSD. Now after the replacement was done i have very thin vertical green lines on the screen.
The steps i have done so far but did not fix the problem are:
- Resetted PRAM / NVRAM
- Clean new installation of OS X
- Put off DDRAM modules
Also i took a screenshot from the desktop and the lines are visible here as well on the image. That somehow indicates to me there might be a problem with the graphic card? I just wonder because i not touched it.
These green lines are also visible immediately after the iMac is starting up after a reboot or shutdown.
There is also a white space border to the left side of the display for about 20 pixels width or so.
Do you might have any suggestions to me what i could still try to do.
There is no apple warranty anymore and i also don´t want to spend money here for getting a new graphic card (if that is really the problem).
Here´s the screenshot i took showing green vertical lines in white areas.
Это хороший вопрос?
3 Комментариев
The screenshot won't show LCD defects at its capturing what is held in your systems memory as you can see its just fine here. You would need to take a picture with your phone or other digital camera.
из Dan
You are right. If looking at the screenshot on another device i also can´t see any issues.
из Roman Müller
I noticed they are not there "permanent" again somehow. If it hit against the monitor a little they are gone but come back again at a random time.
из Roman Müller
