Where can I get the glue to reassembly the Keyboard?
Hey Guys, where can i get the glue to reassembly the keyboard? Which kind of glue has to be used? Can i use regular hot glue? Thanks!
Это хороший вопрос?
Это хороший вопрос?
I would not use hot glue as it will release when the base gets hot during use. A very light coat of contact cement will do the trick.
Был ли этот ответ полезен?
https://www.tesa.com/en/industry/tesa-61...
I used 2mm to put mine back together. Might be worthwhile getting a mix of 1mm, 2mm, 3mm, and 4mm if you want to be thorough. Otherwise, just 2mm does the job.
I used only 2mm tape on mine and after 6 months it is coming loose in the places where the original tape was wider. It's too bad that someone doesn't sell the tape in a template like it used at the factory.
За последние 24 час(ов): 0
За последние 7 дней: 2
За последние 30 дней: 8
За всё время: 897
