Xbox One — третья по счёту игровая приставка от компании Microsoft, являющаяся преемником Xbox 360.
727вопросов Показать все
Why is my Xbox one shutting off after a varied amout of time?
About 2-3 weeks ago I opened my Xbox one up to clean all the dog hair and dust out. When I put it back together and tried turning It on it would start booting for about 15 seconds then shut off. If I leave the console plugged in for an extended period of time it will stay on for longer. I've managed to get into battlefield V and start loading a single player mission but while loading it shut off. It does a complete shut down even.
  • The fan doesn't ramp up hard before it shuts off
  • The power brick doesn't have any detrimental led changes(I haven't tested it on a different console not have I tested a different power brick)
  • I made sure that everything is plugged in
  • The board doesn't appear to be damaged
  • I've done various “fixes" for similar problems but none worked
At this point im about to buy a one x but I would still like to see if I can fix it
Это хороший вопрос?
Оценка 0
Добавить комментарий
1 ответ
Of course we must assume that you broke something while cleaning it, give it another serious visual inspection, maybe you broke the lead on a component or shorted something out with some dirt that was left behind, did you disconnect any ground wires going from one place to another, loose or missing screw not making good ground?
Был ли этот ответ полезен?
Оценка 0
Добавьте свой ответ
Eduardo Partida будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 1
За последние 30 дней: 1
За всё время: 24
