The March 2015 update of Apple's 13" MacBook Air features fifth generation Intel Core i5 and i7 processors, resulting in slightly increased performance and battery life.
623вопросов Показать все
Why is my MacBook Air with minor liquid damage stuck in a boot loop?
I recently had a minor liquid spill on my macbook air (a couple splashes of soda from a nearby library goer) that landed mostly near the vents and a little bit on the keyboard. I let it dry out for 3 days upside down and opened up the case to see if there were any stray liquid puddles left behind. there are a couple sticky drops but everything is dry and nothing looks corroded.
However, when i first tried to boot up after the drying period i got no response. i did an extended smc reset with no luck and ended up unplugging the battery booting up and replugging the battery. this seemed to work and it will now boot up to the main account log in screen but when i type in my password the load bar pops up and the machine shuts down before shortly restarting. i tried going into recovery and internet recovery mode but they just load and then crash in the same way before restarting.
i also noticed that the machine won’t start up when i press the power button. it only starts up if i unplug and replug the magsafe charger. the battery itself is still charging however.
any ideas on what the issue could be? i already know apples going to try and sell me a whole new machine or have crazy repair costs and i’m a little wary of third party repair services
Это хороший вопрос?
Оценка 0
1 Комментарий
I find it then a bit weird you're coming to look for help on a forum hosted by a third party spares supplier and answered by lots of participants who run third party repair services you're wary of.
из
Добавить комментарий
1 ответ
Наиболее полезный ответ
So if I take a glass of water and add to it a bunch of salt or sugar and then allow the water to evaporate the salt or surgar will also disappear?
Sorry to tell you all you’ve done is concentrated the solids in the drink that was spilled into your system letting it dry out on its own .
That won’t solve the issue here as the solids are slowly corroding your parts and could have created a short which can damage things more so.
Time to find someone who you trust to clean out your system if its possible. Given what you’ve stated I suspect it has a bit more than cleaning is needed here.
If the logic board got the brunt of it I would just replace it and be done with it.
Был ли этот ответ полезен?
Оценка 1
Добавьте свой ответ
Rachael G будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 9
За последние 30 дней: 25
За всё время: 1,125
