Fuse location Samsung washer WF45K6200AW/A2
No power to panel. Got continuity through noise suppressor. Got board out. nothing looks like a fuse.
Это хороший вопрос?
Это хороший вопрос?
cliff.witt looks like the only fuse is on the inverter just below connector CN5
Let’s hope this will help you to get started
Был ли этот ответ полезен?
Thanks OT. The diagrams will be very helpful. Will check next couple of days & get back to you Cliff
Back at it. Again thanks for diagrams and help. I located what looks like a fuse where you said. Checked continuity ok. No continuity through main relay probably to be expected since no power. Having a hard time determining what energizes this relay. Thinking if I jump contacts should fire up the rest of machine. Any suggestions. Really don't want to blow anything up. Thanks again Cliff
Can you check if you have power on #2 of the power relay and #1 of the heater relay (White cable). If so you should be getting power to the relay.
OK thanks will try that tomorrow
Not sure of relay locations. Do you have pictorial of physical location. Thanks Cliff
Run through this video and see if it helps locate your issue. I got nothing with that model number.
Thanks Mayer. Already say that video. No help. There seems to be some confusion whether this model even has a fuse. I’m a retired electrical engineer so have some insite into this sort of thing, but can’t locate anything that looks like a fuse.
Please post a photo of your control board and we'll see if one of the pros around here can spot the fuse if it has one. Also please check the model number you gave.
Thanks Mayer. Number is correct S/N is OFFA5AEJC00209F if that helps. I will send photo when I figure out how
Nope, please check the model number you gave.
Model number also correct
За последние 24часов: 13
За последние 7 дней: 48
За последние 30 дней: 196
За всё время: 8,804
2 Комментариев
Did you get yours to work? I know this is years ago for you but having the same problem now. So frustrating.
из Sherece Spence
Samsung Model # WF45R6100AC/ US. I Cleaned filter and detergent despencer once completed turnedthe system on the screen comes on, when you start the wash all you get is a ticking sound the the system turns off.
из Robert Landis
