Portable Bluetooth speaker released in June 2015. The speaker features ClearAudio+ Technology and LDAC Technology. Model Number: SRS-X55.
My adapter is broken on my speaker
The yellow part where you charge the Sony SRS-X55 is broken. How can I replace this?
Это хороший вопрос?
Оценка 1
Добавить комментарий
Ответов (2)
Наиболее полезный ответ
Darla Dang that is your DC in jack. It is soldered to the I/O board. Remove that board by using this guide Then check if you can unsolder it and find a replacement based on the dimension from places like mouser. com or digikey.com etc. Not a terrible complicated repair but it does require some soldering skills.
You can get the jack connectors from here https://ru.aliexpress.com/item/202656625...
Был ли этот ответ полезен?
Оценка 1
The port the charger goes in the pin has come off the male component that's inside the speaker so I think I need a new connector so then I can charge as normal cheers
Оценка 0
Добавьте свой ответ
Darla Dang будет очень признателен(а).
Статистика просмотров:
За последние 24 час(ов): 0
За последние 7 дней: 2
За последние 30 дней: 7
За всё время: 457
