The Samsung Galaxy S4, model i9505, features a 13-megapixel rear camera, and a 5-inch 1080p display.
523вопросов Показать все
My Galaxy S4 has the sound on but the phone is black.
Ok so my mom had this Samsung 4 and it just stopped working. What I did was charge it and it Charged. I tried to turn it on but it wasn’t’ turning on. It always plays songs randomly and when I plug in the charger it makes the sound to tell you it is charging. I looked on youtube and I researched and I DID EVERYTHING. I pressed volume up/down the home button and power button I took out the battery and held the power button for 5 minutes then It still didn’t work. I tried everything and also I don’t have to tools to open the screen and I am not wasting 200-300 dollars for a screen repairment. I am desperate to fix it since my other phone broke.
Это хороший вопрос?
Оценка 0
Добавить комментарий
1 ответ
Выбранное решение
Seems like it is most likely an LCD fault, but there is no way to guarantee without another LCD to test with.
Not sure where you got quoted 200-300 dollars, but the parts are only around $30 and some even come with the tools to repair.
This is an easy repair that you could likely do yourself by following an ifixit guide using some very basic tools.
Samsung Galaxy S4 Display Assembly Replacement
Был ли этот ответ полезен?
Оценка 1
1 Комментарий:
Thank you so much. It finally worked you truly are the best. :D
из
Добавьте свой ответ
Delsin Rowe будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 2
За всё время: 57
