Hi Nana Kwame
You mentioned that your laptop work and the adapter is damaged.
The easiest way is to test it, either find a spare or test it directly at the computer shop.
If the replacement adapter works, you purchase it. I think most shop are generally fine to do this test.
Do not test the old power adapter as it is not recommended. Most probably it has been shorted out and water will start working inside the circuit, damaging it further, corrosion and misc.
For the socket, I presume it is your power outlet.
There are some possibilities, either water is still inside the plug thus circuit breaker has been activated to cut off.
internal power socket has been corroded or damaged by water, so as the wires which might be damaged / rot.
For the power outlet, if you are unsure, check with a qualified electrician for troubleshooting.
Somehow I also think if you have insurance, you might like to check if they cover those damages, which you can claim on.
Был ли этот ответ полезен?
Проголосовали
Отменить
Оценка
2
Отмена
Scroll through this thread to find the appropriate place for this comment. Then, click "Attach comment to this post" to move it.
