Выпущен в марте 2017 года, идентифицируется по номеру модели SM-J727
J7 Crown Black Screen
I have a J7 Crown S767VL that has no screen display it stays black phone is still powered on and when I try to hard reset it doesn't fix the issue I have tried to power off by holding power + volume down button for 20+ seconds and after about 15 seconds of holding buttons it vibrates every 1-1.5 seconds and does not power off. I have been attempting to factory reset with black screen with no luck and have exhausted my options available online. Please give me suggestion(s) on what I can do it is a straight talk phone.
Это хороший вопрос?
Счет 4
Добавить комментарий
1 ответ
It sounds like an LCD fault. Has the phone been dropped in water or dropped on a hard surface?
Был ли этот ответ полезен?
Счет 0
12 Комментариев:
I do not believe it has gotten wet or dropped, it is in pretty pristine condition as far as I can tell I was thinking it was a corrupted firmware issue
из
You will need a new LCD if you haven taken phones apart then you can replace the screen yourself or take it to a repair shop. It will be a whole lot cheaper replacing it yourself if you do that go here https://www.amazon.com/Replacement-Digit...
из
Is there a way to try to perform a factory reset without the ability to boot in recovery mode and being unable to do it through settings?
из
Hope this helps
из
Yes if you have a computer
из
Показать ещё 7 комментариев
Добавьте свой ответ
Corbin Dallas буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 6
За последние 30 дней: 21
За всё время: 1,937
