The Samsung Galaxy S9 is identified by its model number: SM-G960XU. It is the ninth generation of Samsung's Galaxy Series that was released in March 2018. Available in Lilac Purple, Midnight Black, and Coral Blue.
119вопросов Показать все
Can I retrieve data (photos/videos) from a completely shattered s9?
The front and back of my s9 is completely shattered, however when it first broke it was still able to charge and power on. The phone still received notifications (the light would also blink), receive calls, set off alarms and all that stuff. Well I left it alone for a few days and when I went to charge it again the phone will not buzz like it's charging or cut on (I'm assuming it's dead) why will it automatically not charge now? Is the port broke? Is there any possible chance of getting my photos/videos back they have all of my son's photos since birth on there.
Это хороший вопрос?
Оценка 0
Добавить комментарий
2 Ответов
If you charge it and try turning it on, then hook it to the computer. It should recognize it and ask if you want to import your pictures and videos. If you can't get that to work i would recomend contacting iPad rehab at iPadrehab.com and see if they can get your data. They usually charge 300 dollars for iPhones and guarantee it or no charge, I don't know if they do this with Samsung. I would call them if you can't get it to get the pictures off. You may just need to put a new screen on the phone so you can unlock it. You can put a new screen on it fairly easily, what a few of the videos from YouTube and follow the directions one step at a time. Get a basic set of tools and also get a magnetic parts board to keep track of all of the screws ( some screws may be different lengths so make sure that they are put back in the same place or it can damage the motherboard). If you think this is above your skill level or aren't interested check with ifixit and they can direct you to a repair shop in your area. Best of luck.
Был ли этот ответ полезен?
Оценка 0
What if you put the phone into twrp and just dragged the files you need to your pc? Or you can use some broken Samsung recovery tool.
Оценка 0
Добавьте свой ответ
Bnl будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 1
За последние 30 дней: 3
За всё время: 87
