Nintendo's upgraded version of the Nintendo 3DS. It features bigger screens, longer battery life, better pixel density, and a better design.
412вопросов Показать все
Why does my 3ds turn on , blue light, then pops and turns off
A while ago I was fixing the lcd of my 3ds xl and I got done and I gave it to my brother who dropped it now when ever he turn it on it would cause the problem above so now I got back to it and replace all the top screen ribbons, lcd, camera , speaker which the actual speakers have broke off and still it’s doing that popping thing. Why?!? Can anyone help me
Это хороший вопрос?
Оценка 1
Добавить комментарий
1 ответ
Выбранное решение
Are all the cables connected? I know that when the DS Lite it’s upper screen isn’t correctly seated, it will cause the same issue as you describe. Also check the motherboard to check if nothing fell off or is damaged.
Был ли этот ответ полезен?
Оценка 3
22 Комментариев:
How do I make sure nothing fell of or is broken
из
Are you able to open it up again ? You should take a look inside to see if all is OK.
из
Anything specific to look for because everything to me seems fine , maybe the p7 connector is broken
из
I held down the p7 connector and It still popped
из
I uploaded pictures of the motherboard
из
Показать 17 больше комментариев
Добавьте свой ответ
Nic будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 2
За последние 30 дней: 7
За всё время: 370
