Model A1286. Released February 2011 / 2.0, 2.2, or 2.3 GHz Quad-core Intel Core i7 Processor
586вопросов Показать все
My computer had a stroke, what do I do?
All of a sudden trying to upload a YT video the Mac started spazzing out and shut down. Now there are random lines across the display and it’s stuck on the startup screen.
Computer is a MacBook Pro "Core i7" 2.0 15" Early 2011.
Это хороший вопрос?
Оценка 0
8 Комментариев
Can you give us your exact model.
Look at the bottom cover hopefully you can read the S/N and then plug it into here EveryMac - Lookup. Let us know what you find.
из
I'd put money on it being the 2011 15" MBP
из
@mayer - Likely ;-}
из
It's Model A1286 and that's all the info I can provide for now
из
@Techno Spyform1 - Sorry need a bit more here ;-{
Here's all of the A1286 Models can you pick yours out?
из
Показать 3 больше комментариев
Добавить комментарий
2 Ответов
Выбранное решение
Plug the serial number from the back of your machine in here and then tell us what you have:
https://everymac.com/ultimate-mac-lookup...
UPDATE 11/6/19
That the exact machine I was betting on. Your GPU has gone bad. This is a very well know issue on this model. Apple was repairing it for free for a while but that program is over.
https://www.macrumors.com/2017/05/20/app...
Best thing to try is installing gfxCardStatus. This will enable you to turn off the dual graphics. It works OK but limits your ability on graphic intensive programs like PhotoShop:
https://gfx.io
Был ли этот ответ полезен?
Оценка 3
4 Комментариев:
I mentioned in the non-answer comments it's an A1286 model
из
из
How do I install it if I can't get past the boot screen?
из
I found an answer on the Internet to the GPU problem and I would like to thank you for pointing it out!
из
Try using option command p r! :)
Оценка 0
1 Комментарий:
No that did not work, the computer kept restarting over and over until I let it go
из
Добавьте свой ответ
Techno Spyform1 будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 2
За последние 30 дней: 2
За всё время: 293
