Why is it impossible to shift gears when my 1995 Ranger is hot?
I can drive my 1995 Ford Ranger for 30 minutes , and then it becomes impossible to shift gears until it cools for 90 minutes. What is wrong with my truck ?
Update (11/08/2019)
The 1995 Ford Ranger with a 2.3 liter engine has a 5 speed manual transmission.
Это хороший вопрос?
Auto or manual?
из sm_vulkus
Hi @dtennisman ,
Have you checked the level of the transmission oil in the gearbox?
Do this on level ground.
из jayeff
Did you rebuild or buy it
из Noah Byrum
I will check the transmission fluid level, that seems like an important thing to do. I did not rebuild the transmission, it is original equipment with probably 200,000 (the odometer died 12 years ago), or more miles on it.
из otrecords
Noah, thanks for the suggestion, but I definitely don’t grind my gears.
из otrecords
Показать 1 больше комментариев
