Replace SSD--Same as last year's model?
Can you replace the SSD in the 11" MBA (mid 2011) the same way you replace the SSD in the last 11" model?
Это хороший вопрос?
Это хороший вопрос?
I think it comes apart the same and uses the same SSD
All Apple did was bump the specs up
Был ли этот ответ полезен?
I'm not sure this is always the case.
I tried moving this hard drive from a Late 2010 13" Late 2010 MBA into a 2011 13" MBA and all I could ever see was the "No" sign.
- Jeff
Capacity: 251 GB (251,000,193,024 bytes)
Model: APPLE SSD SM256C
Revision: AXM09A1Q
Serial Number: S0N8NEAB127960
Native Command Queuing: Yes
Queue Depth: 32
Removable Media: No
Detachable Drive: No
BSD Name: disk0
Medium Type: Solid State
TRIM Support: Yes
Partition Map Type: GPT (GUID Partition Table)
S.M.A.R.T. status: Verified
Volumes:
disk0s1:
Capacity: 209.7 MB (209,715,200 bytes)
BSD Name: disk0s1
Content: EFI
jeffme hd:
Capacity: 209.48 GB (209,484,214,272 bytes)
Available: 139.14 GB (139,138,199,552 bytes)
Writable: Yes
File System: Journaled HFS+
BSD Name: disk0s2
Mount Point: /
Content: Apple_HFS
Recovery HD:
Capacity: 650 MB (650,006,528 bytes)
BSD Name: disk0s3
Content: Apple_Boot
BOOTCAMP:
Capacity: 40.52 GB (40,521,998,336 bytes)
Available: 18.29 GB (18,286,682,112 bytes)
Writable: No
File System: NTFS
BSD Name: disk0s4
Mount Point: /Volumes/BOOTCAMP
Content: Microsoft Basic Data
Ok - please scratch my doubt, listed above. With further research, the SSDs in the 2011 MBAs are the same as in the Late 2010 MBAs - the Samsung AXM09A1Q.
The resolution to my problem was identified by a poster in another forum - apparently, you must, must, must format / reinstall the OS on the new machine via the Lion Internet Recovery function (cmd+option+r at the chime). This involves creating a Lion Internet install USB recovery key before going through this process.
За последние 24часов: 1
За последние 7 дней: 1
За последние 30 дней: 2
За всё время: 3,583
