Which SSD blade is more compatible?
Hi,
I have iMac 27” Retina 5K model. The model number is A2115, SMC-3194.Can anyone suggest the compatible blade SSD? I need performance. I shall buy 1TB of blade SSD. Is it possible to install Windows, Linux and Mac on blade SSD? The fusion drive setup only give performance for Mac OS. If I replace Blade SSD, will it give the full performance of MVME SSD with Windows and linux?
Это хороший вопрос?
3 Комментариев
Here's a good reference on the different Apple blade SSD's The Ultimate Guide to Apple’s Proprietary SSDs
из Dan
Apple Samsung unit price is high.
Would you please recommend other models?
из Inam Ahmed
@inamahmed - As Apple uses their own custom design you are stuck here. I only install Apple SSD's in the iMac's as its located so deep within the system. There are two other makers OWC and Transcend check them out
из Dan
