Random off balance spinning
Top load washer will randomly start making load knocking noise during middle of spin cycle as if the clothes were not balanced.
Это хороший вопрос?
Это хороший вопрос?
Sounds like a counter balance spring (least that is where I would start). Luckily Kenmore/whirlpool are pretty easy to pop open if it is an older model.
Pop the shell off and take a look at the bottom back end of the tub see if the spring is broke/not connected. If it is broken get a replacement but sometimes the hole the hook is in will be broken. Just drill a new hole in the frame. and re-connect.
There are videos if you need a play by play.
Был ли этот ответ полезен?
За последние 24часов: 1
За последние 7 дней: 5
За последние 30 дней: 10
За всё время: 118
