Salter модели 1036 — это цифровые дисковые кухонные весы с максимальной грузоподъемностью 5 кг или 11 фунтов.
Opening the battery compartment
The screw holding the battery compartment shut is so tiny and so tight I cannot open it, despite trying very small screwdriver and smallest allen key. They are all too big!
Это хороший вопрос?
Счет 1
2 Комментариев
There is no screw holding the cover
из
there is on my scales too. Looks like it has been put on as an afterthought because it came open too easily
из
Добавить комментарий
2 Ответов
Наиболее полезный ответ
@deirdremoylan without actually seeing it or knowing the size of it I would recommend a really good tool kit something like this Mako Driver Kit - 64 Precision Bits or even this one Manta Driver Kit - 112 Bit Driver Kit With those kits you will always have the right tool for any repair.
iFixit's 4 mm aluminum screwdriver handle with magnetic bit socket, knurled grip, and swivel top — plus 64 essential precision bits to tackle sneaky security screws. Изображение
Товар
$39.95
Our most comprehensive bit kit for the ultimate repair enthusiast. 112 bits designed to fix every household tech device. Изображение
Товар
$69.95
Был ли этот ответ полезен?
Счет 2
3 Комментариев:
Dear Oldturkey03, Thank you so much for taking the time to reply to my enquiry. I actually have a kit with 75 precision bits (different make, I live in Ireland) and there is nothing small enough in it. However I notice that your bigger kit has possibly some even smaller sizes - 0001 crosscrew. I will try and get one in a hardware store (I don't want to spend 3 times as much on another bit kit as I spent on the scales for the sake of one little bit!) But I really appreciate your help. Thanks. Deirdre
из
@deirdremoylan agree with what you are saying. If nothing else and ,depends on your town/city, a good jeweler will always have the right tools to help you out.
из
Brilliant idea! (My watch has a similar sized screw, now I think about it, and has to be dealt with when I get a new battery.) Thanks a lot!
из
I have a small screw driver to fit this screw, still does need t open it. Looks like new scales, but not Salter. Rubbish!
Счет 0
Добавьте свой ответ
FinntheCool буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 7
За последние 7 дней: 23
За последние 30 дней: 61
За всё время: 9,404
