What is this rubber ring?
Hi all.
I have changed the drive on a HP y0a95ea#uuw.
But I have a black rubber ring what is that for?
Thanks.
Regards Daniel
Это хороший вопрос?
Hi all.
Thanks.
Regards Daniel
Это хороший вопрос?
usually, with hard drives, they use little rubber things like the one you have to reduce vibrations in the mount of the hard drive. It probably fits in somewhere around the mounting mechanism for the hard drive.
I imagine it would go go in one of the circled areas.
Был ли этот ответ полезен?
Hi. Thanks for that. I only have 1 but I have switched to ssd so i think All good but meny Thanks
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 0
За всё время: 134
Hi @danielpt I tried looking up the model number you gave, and I can't find anything. could you double check your model number? https://support.hp.com/us-en/document/c0...
из Aiden
I think I found it. apologies.
из Aiden
