The Nomad is a hoverboard with 7" diameter wheels manufactured by Hover-1. In addition to standard hoverboard functionality, the Nomad also includes Bluetooth audio playback and LED headlights.
2вопросов Показать все
Both indicator lights are red and wont stop beeping
Battery indicator and pad indicator lights are both steady red and it's steadily beeping, if I plug in the charger, lights turn to Orange and beeping stops, but when I unplug it, it goes back to red and beeping, only way I could get it to stop was remove the bottom and unplug battery
Это хороший вопрос?
Оценка 2
Добавить комментарий
1 ответ
Выбранное решение
Couple different things:
Usually the beeping and lights is a low battery, as you stated you have been charging the battery. Did you ever run the battery to completely dead? As that may have caused damage to the battery may leading to replacement.
The other option is that it needs to be re-calibrated by doing the following (from operating manual)
  • Make sure you have hover board on flat/even surface
* Mats should be even with eachother not tilted forward or backward.
  • Press and hold the on/off button for 15 seconds. Scoot will turn on.
  • Turn the board off and then turn the board back on.
  • Press power button twice and it should be calibrated
Был ли этот ответ полезен?
Оценка 1
2 Комментариев:
Once I unplug it from the charger, it goes red and starts beeping, it will not turn on, so I would be unable to calibrate it, and I'm not sure about the battery, my son brought it to me like this and said it won't turn on or off, so I'm not sure the condition before this started
из
Sounds like a battery issue, if you are going to pop it open you can check for loose connections. Not sure if Hover-1 has replacement internals that are not after market. But I know my kid i could buy the internals pretty readily. Now they want a one wheel so that is my next project to figure out if it's even worth it....
из
Добавьте свой ответ
Jarrod Harvey будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 15
За последние 7 дней: 58
За последние 30 дней: 244
За всё время: 9,592
