The JBL Charge 3 can be recognized by its distinct woven speaker cover and rubber accents. It was released in 2016 and features a fully waterproof design, 20 hours of playback time, and bluetooth connectivity.
90вопросов Показать все
My JBL Charge 3 turns off by itself.
When i turn on my JBL Charge 3 it turns off after couple seconds. After it has turnined off couple times it stays on and when i turn it off, it just does the same thing. It’s my second day with it so its brand new…
Это хороший вопрос?
Оценка 0
Добавить комментарий
2 Ответов
Выбранное решение
My charge 3 recently had the same issue after some weeks of inactivity, the speakers would just shut down almost instantly without reason (full battery level indicator and it charged correctly so it didn't seem likely to be at fault here). Then I realised the battery sensor problem that appeared a few days ago on my Android phone (battery level status showing negative digits) could be causing the connected device to turn off, and so it was. Try pairing it to a different device and see if this solves, in that case I would also hard reset the speakers (press and hold volUP+play/pause until it turns off) to avoid automatic connection to the faulty device, notice that this will clear the memory of all devices paired in the past.
Был ли этот ответ полезен?
Оценка 1
Наиболее полезный ответ
If your JBL Charge 3 speaker is not charging or not holding a charge, see the JBL Charge 3 Won’t Charge or Won’t Hold a Charge problem page for possible problems and solutions.
Оценка 1
Добавьте свой ответ
VeryRareHenny будет вечно благодарен.
Просмотр статистики:
За последние 24часов: 7
За последние 7 дней: 31
За последние 30 дней: 131
За всё время: 3,170
