Обновление MacBook Air 11" от марта 2015 года оснащено процессорами Intel Core i5 и i7 пятого поколения, что обеспечивает небольшое увеличение производительности и времени автономной работы.
What screwdriver do I need to open the battery panel? MacBook Air 2015
I spilled a little vinegar on my laptop days ago. I’ve just got the right screwdriver to open the back of it but I’ve discovered that I need two different screwdrivers to open the battery panel. Where can I get this in stores! Please help! Thank you. MacBook Air 2015
Это хороший вопрос?
Счет 0
Добавить комментарий
1 ответ
Наиболее полезный ответ
Here’s the iFixit guide you need to follow: Замена аккумулятора MacBook Air 11" начала 2015 года
You need the following screw drivers:
Precision fixed blade screwdriver engineered by iFixit. Изображение
Товар
T5 Torx Screwdriver
$5.49
Compatible with the type 5IPR fasteners used on MacBook Air, MacBook Pro Retina Display laptops, and Toshiba drives. Precision fixed blade screwdriver engineered by iFixit. Изображение
Товар
P5 Pentalobe Screwdriver Retina MacBook Pro and Air
$5.99
Был ли этот ответ полезен?
Счет 2
3 Комментариев:
My laptop isn’t turning on. Do you think the batteries are just the problem? Where do I get new ones?
из
Before you jump into getting a battery. How about doing some basic tests.
When you plug in your charger what color is the MagSafe plug Amber or Green?
If the charger is not lighting inspect the contacts for damage and clean the contacts if needed.
Is the charger the correct one for your system?
из
The charger lights up when I plug it in. It turns from green to amber. I don’t want to start my laptop again because it shortens it. When I start it it turns on and then shuts down real quick. I can’t believe it’s not working. When I spilled a minuscule of liquid on it and wiped it up right away. I don’t see any corrosion inside nor any liquid. I don’t know what’s the problem. If you could please help me thank you
из
Добавьте свой ответ
aimee буду вечно благодарен.
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 4
За последние 30 дней: 29
За всё время: 10,170
